Black Friday. Marked 3 Pro and the permanent unlock are $39.99 through November 30, before the regular price goes up in the New Year. Already applied on the Mac App Store. At Paddle checkout, use code BLACKFRIDAY26.
Marked QL app icon
Instant Markdown Preview in Quick Look
Press Spacebar in Finder and see fully rendered Markdown — math, diagrams, code, and more — powered by Apex.
Requires macOS 13.0 or later
Quick Look not working?
Step-by-step registration, conflict fixes, and Terminal diagnostics.
Troubleshooting guide
Wrong app winning Spacebar?
Quick Look Doctor — free utility to prefer one handler and ignore conflicting peers.
Get Quick Look Doctor
Everything you expect from great Markdown preview
Apex-powered rendering
Unified Markdown processing that combines your favorite flavors in one engine.
Math & diagrams
MathJax for LaTeX math and Mermaid for flowcharts, sequence diagrams, and more.
Syntax highlighting
Colorful code blocks with highlight.js and a choice of syntax themes.
Dark Mode support
Preview styles that follow system appearance for comfortable reading at night.
Configurable styles
Choose preview styles, Apex processing mode, and optional custom CSS.
Instant in Finder
Select a file and press Spacebar — no app to launch, no window to manage.
Plus some advanced features
Table of Contents navigation
Jump between headings in longer documents without leaving the Quick Look preview.
Quarto support
Preview .qmd files with Apex’s Quarto mode for Pandoc-style Markdown.
Customizable Front Matter display
Show, hide, or style YAML and other front matter to match how you work with metadata.
Get Marked QL
Choose your preferred way to get Marked QL
Paddle
Direct download — $9.99 one-time, free trial available
Free Trial
Mac App Store
$9.99 one-time purchase
Mac App Store
Setapp logo
Setapp is the best place to get apps. Buy Marked QL on Setapp or get it with dozens of other apps in one subscription for $14.99/mos. + tax. No extra fees, no ads.
Try Free
Apex Markdown icon
Powered by Apex
Marked QL uses Apex, a unified Markdown processor that combines CommonMark, GitHub Flavored Markdown, MultiMarkdown, Kramdown, and more. Write in the syntax you already know and get consistent, beautiful output in Quick Look. Apex is also planned for integration into Marked 2 in 2026.
Frequently asked questions
Do I need Marked to use Marked QL?
No. Marked QL works on its own as a Quick Look extension for Markdown files. If you also use Marked 3, Marked QL can share preview styles.
How do I preview a Markdown file with Marked QL?
Select any supported Markdown file in Finder and press the Spacebar. Quick Look opens with a fully rendered preview. Marked QL registers as the Quick Look generator for Markdown files after installation.
Can I use Marked QL from Terminal?
Yes! See below.
What Markdown syntax does Marked QL support?
Marked QL uses Apex, a unified Markdown processor that combines CommonMark, GitHub Flavored Markdown, MultiMarkdown, Kramdown, and more. It supports tables, footnotes, math (MathJax), Mermaid diagrams, syntax highlighting, task lists, callouts, and many other extensions.
Which macOS versions are supported?
Marked QL requires macOS 13.0 or later.
How does Marked QL relate to Marked 3?
Marked QL is a lightweight Quick Look companion for instant Finder previews. Marked 3 is a full live-preview app with export, proofreading, custom styles, and editor integration. They work great together, but each app stands on its own.
Quick Look from Terminal
macOS includes qlmanage, a command-line tool that opens Quick Look for any file or folder. Add a short shell function and you can preview Markdown from the command line — if Marked QL is registered as your Markdown viewer, you get the same rendered preview as in Finder.
For example, run ql README.md in a project directory to open a Quick Look preview of your readme without leaving Terminal.
Fish
function ql --description 'Quick Look a specified file or directory'
  if [ (count $argv) -gt 0 ]
    qlmanage >/dev/null 2>/dev/null -p $argv &
  else
    echo "No arguments given"
  end
end
Bash / Zsh
ql() {
  if [ $# -gt 0 ]; then
    qlmanage >/dev/null 2>/dev/null -p "$@" &
  else
  fi
Add the function to ~/.bashrc, ~/.zshrc, or ~/.config/fish/config.fish, then restart your shell or run source on the file.
Marked QL is a perfect companion to Marked 3 when you want instant Finder previews, while Marked adds live editing preview, proofreading, export, and deep editor integration. Already a Marked user? You will feel right at home.
Quick Look not working? See the troubleshooting guide.
