Preferences: Proofing
Options in the :
- Always open new documents in proofing mode
- New documents will default to showing keyword highlights
- Enable CriticMarkup automatically when syntax is detected
- Enable CriticMarkup processing automatically when appropriate syntax is detected
- Highlight Markdown syntax errors
- Highlight broken Markdown links and other markup that may have converted improperly
Keywords
Define lists of keywords to be highlighted
- Ignore Repeats
- Use the field below to create a list of words—one per line—that you’d like universally ignore when using “Visualize Word Repetition”
Next up: Preferences: Export ▶
