HTML SpecificĀ Settings
Disable AutomaticĀ HeaderĀ IDs
Marked includes an option to disable automatic header ID generation. You can find this option in the Marked Settings, Processor pane.
Random FootnoteĀ IDs
In the Processor pane, you can check the ā€œUse Random Footnote IDsā€ to generate random footnote identifiers, which helps avoid conflicts when multiple documents are displayed on one web page. This option is only available when using the MultiMarkdown processor.
Process Markdown InsideĀ ofĀ HTML
By default, Markdown syntax inside of HTML block tags is usually ignored by Markdown processors. This option forces Marked to continue processing within block elements. Note that some markup may cause issues.
Next up: Embedding JavaScript ā–¶
