Markdown Overview
What is Markdown?
Markdown is a lightweight markup language that allows you to write using an easy-to-read, easy-to-write plain text format, then convert it to structurally valid HTML. The overriding design goal for Markdown’s formatting syntax is to make it as readable as possible.
Basic Syntax
Headers
Create headers using hash symbols (#). The number of hashes determines the header level:
# Header 1
## Header 2
### Header 3
#### Header 4
##### Header 5
###### Header 6
Emphasis
Bold text using double asterisks or double underscores:
**Bold text**
__Bold text__
Italic text using single asterisks or single underscores:
*Italic text*
_Italic text_
Lists
Unordered lists using asterisks, plus signs, or hyphens:
* Item 1
* Item 2
* Item 3
+ Item 1
+ Item 2
+ Item 3
- Item 1
- Item 2
- Item 3
Ordered lists using numbers followed by periods:
1. First item
2. Second item
3. Third item
Inline links with the text in square brackets and the URL in parentheses:
[Link text](http://example.com)
Reference links with the text in square brackets and a reference in square brackets:
[Link text][reference]
[reference]: http://example.com "Optional title"
Automatic links by wrapping URLs in angle brackets:
<http://example.com>
<user@example.com>
Images
Images use similar syntax to links but with an exclamation mark at the beginning:
![Alt text](http://example.com/image.jpg)
![Alt text][image-reference]
[image-reference]: http://example.com/image.jpg "Optional title"
Blockquotes
Create blockquotes using the greater-than symbol (>) at the beginning of each line:
> This is a blockquote.
> It can span multiple lines.
> You can have multiple paragraphs in a blockquote.
Code
Inline code using backticks:
Use `code` in your text.
Code blocks by indenting with four spaces or one tab:
    This is a code block.
    It preserves formatting and spacing.
    Multiple lines are supported.
Horizontal Rules
Create horizontal rules using three or more hyphens, asterisks, or underscores:
___
Line Breaks
Hard line breaks by ending a line with two or more spaces:
This line ends with two spaces.
This creates a hard line break.
Soft line breaks by simply pressing Enter (creates a space in HTML):
This line
continues on the next line with a space.
Escaping Characters
Escape special characters using backslashes:
\*This text is not italic\*
\[This is not a link\]
Common characters that can be escaped:
  • \ backslash
  • ` backtick
  • * asterisk
  • _ underscore
  • {} curly braces
  • [] square brackets
  • () parentheses
  • # hash
  • + plus
  • - minus
  • . period
  • ! exclamation mark
Best Practices
  1. Use blank lines to separate different elements for better readability
  2. Be consistent with your formatting choices (e.g., use either * or _ for emphasis)
  3. Keep it simple - Markdown is designed to be readable as plain text
  4. Test your output to ensure it renders as expected
  5. Use meaningful link text instead of generic phrases like “click here”
Common Patterns
Nested Lists
1. First item
   - Nested item
   - Another nested item
2. Second item
   - More nested content
Lists with Paragraphs
1. First item
   This is a paragraph under the first item.
2. Second item
   This is a paragraph under the second item.
Blockquotes with Other Elements
> This is a blockquote with **bold text** and *italic text*.
> - It can contain lists
> - And other Markdown elements
> > Nested blockquotes are also possible.
Summary
Markdown provides a simple, readable way to format text that can be easily converted to HTML. The key is to keep it simple and readable while using the basic syntax elements consistently. With practice, you’ll find that Markdown becomes second nature and makes writing structured content much easier.
This tutorial covers the core Markdown syntax as defined in the original specification. For more advanced features, see the documentation for specific Markdown processors like CommonMark (GFM), MultiMarkdown, or GitHub Flavored Markdown.
Next up: Markdown Dingus ▶
