Live Markdown Preview on Mac
Marked 3 is a native macOS app that watches your Markdown files and updates a live preview as you save. It is a preview and publishing tool â not a Markdown editor â so you keep writing in VS Code, Obsidian, Scrivener, Bear, Ulysses, Word, or any text editor.
What Marked does
- Watches files on disk and re-renders on save (or via streaming preview in supported apps)
- Provides themeable HTML preview, proofreading, and export to PDF, DOCX, EPUB, HTML, and more
- Includes a built-in Markdown Dingus with editing features for quick corrections and testing syntax â not intended to replace a good text editor, but helpful for fixes without switching apps
- Does not replace your primary writing app
Three ways to preview
Open a file â Drag a
.mdfile onto Marked (Dock icon or window). See Opening Files. - Watch a folder or vault â Drag a project folder or Obsidian vault onto Marked. See Obsidian, Multi-File Documents.
- Streaming preview â Supported editors push Markdown to Marked as you type. See Streaming Preview.
Quick picks by editor
| I write in⊠| Start here |
| VS Code | VS Code |
| Obsidian | Obsidian |
| Scrivener | Scrivener 3 Support |
| Bear, Drafts, The Archive | Streaming Preview |
| nvALT | nvALT |
| nvUltra | nvUltra |
| Traverse | Traverse |
| Ulysses | Ulysses |
| Word / DOCX | Microsoft Word |
| MarsEdit | MarsEdit |
| Vim / Emacs / terminal editors | Vim or Opening Files |
| Anything else | Opening Files |
| Full integration list | Additional Application Support |
After preview: export and proofread
- Exporting â PDF, DOCX, HTML, EPUB
- Spelling and Grammar
- Document Statistics
- Custom Styles and Custom Style Generator
Compare Marked to other tools
- Marked vs Obsidian Preview
- Marketing comparison (shorter): Live Markdown Preview on Mac
