Choosing a Processor
Marked can preview the same file with several built-in Markdown processors. Each one makes different tradeoffs between writing workflow (books, blogs, GitHub READMEs) and output control (IDs, classes, metadata). You choose the default in Marked Settings, Processor pane; you can also override the processor per document.
This page summarizes how the four main processors differ. For full syntax details, see the reference pages under Help → Markdown Reference (e.g. MultiMarkdown v5 Specification, Kramdown Specification, CommonMark Specification, Discount GFM Specification).
MultiMarkdown (v5)
Best for: Long-form prose, academic or technical writing, and anything that relies on metadata, citations, and MultiMarkdown-specific features.
Marked ships with MultiMarkdown 5 (see the MultiMarkdown User’s Guide for the upstream documentation).
Strengths
  • Narrative and reference-heavy documents: Footnotes, bibliography/citations, and tables are first-class.
  • Metadata: Standard MultiMarkdown metadata blocks (Key: Value headers) plus transclusion and other MMD conveniences described in the v5 guide.
  • Metadata substitution: Keys from metadata can be inserted in the body with [%key]-style replacement so titles, author strings, and similar values stay in sync with the header.
  • Tables, images, and cross-references: Aligned with the features documented for MultiMarkdown 5.
IDs and manual headings
  • Heading IDs are normalized in a way that tends to produce lowercase, concatenated slugs (no spaces — words run together).
  • For manual header IDs, MultiMarkdown uses the form: ## Headline Text [my-id] (the bracketed identifier after the heading text).
When to pick something else
If you need GitHub-flavored task lists and the exact behavior of GitHub’s current parser, prefer CommonMark (GFM). If you need fine-grained HTML classes/IDs on arbitrary elements, consider Kramdown.
Kramdown
Best for: Documents where you want precise control over HTML output — custom classes, IDs, and attributes, so your CSS can target specific blocks and spans.
The kramdown syntax reference is the authoritative guide.
Strengths
  • Mostly compatible with MultiMarkdown-style habits for everyday Markdown, while adding its own extensions.
  • Inline and block attribute lists (IALs): Attach {: #id .class key="value"} to paragraphs, headers, code blocks, links, images, and more — ideal for Jekyll-style sites and custom stylesheets.
  • Header IDs: kramdown normalizes auto-generated header IDs to lowercase, hyphen-separated words (e.g. my-section-title). For manual IDs, use the {#id} form after the headline text — e.g. Setext: My Section {#my-section} then the underline, or ATX: # My Section {#my-section} (see kramdown’s headers for exact placement and IAL rules).
  • Definition lists, footnotes, smart typography, math blocks: Rich feature set for publishing pipelines that need more than “plain” Markdown.
If you rely on MultiMarkdown-only metadata substitution ([%key]) or MMD-specific citation workflows, MultiMarkdown may be a better fit. For README and repo docs that must match GitHub online, CommonMark (GFM) is usually closer.
CommonMark (GitHub Flavored Markdown / cmark-gfm)
Best for: README files, issue/PR descriptions, and project documentation that should match GitHub’s current Markdown behavior as closely as possible.
Marked uses a GFM-oriented engine (cmark-gfm). The formal spec is the GitHub Flavored Markdown Spec, built on CommonMark.
Strengths
  • Closest match to GitHub: Tables, strikethrough, task list items, fenced code blocks with language tags, and autolinks behave like modern GitHub rendering.
  • Unambiguous parsing: CommonMark defines block/inline precedence and list rules precisely — stricter in some edge cases than “classic” Markdown.pl behavior, but more predictable once you learn the rules.
  • Practical for wrapped text: Paragraph and list rules are designed to behave well with hard-wrapped prose (see the spec’s sections on lazy continuations and lists).
Header IDs
Auto-generated heading anchors are typically lowercase and hyphen-separated, consistent with common GitHub-style slugging.
GFM does not replicate MultiMarkdown metadata, kramdown IALs, or MMD citation workflows. For books, theses, or heavy metadata, use MultiMarkdown or Kramdown as appropriate.
Discount
Best for: A fast, C-based processor that tracks classic Markdown and an older GitHub-flavored feature set — useful when you want behavior closer to original Markdown plus tables, footnotes, and related extensions without the full CommonMark rule book.
Project home: Discount.
Strengths
  • PHP Markdown Extra-style tables and many extensions (footnotes, fenced code when enabled, etc. — see Marked’s Discount GFM Specification for what Marked enables).
  • Optional “GitHub” extras in upstream Discount (e.g. checkbox lists when built with the right flags); Marked documents the combination it ships in the Discount spec page.
  • SmartyPants-style typography and other conveniences described on the Discount site (though all included processors actually provide typography features).
  • Philosophically close to John Gruber’s Markdown plus practical extensions, rather than the full CommonMark test suite.
For pixel-perfect parity with today’s github.com, prefer CommonMark (GFM). For MultiMarkdown metadata and citations, use MultiMarkdown.
Quick comparison
Concern MultiMarkdown Kramdown CommonMark (GFM) Discount
Primary use Prose, papers, books Styled HTML, Jekyll-like sites READMEs, GitHub-like docs Classic MD + extensions
Citations / MMD metadata Strong Via different syntax No No
Manual heading ID style ## Title [id] ## Title {: #id } (IAL) Spec / GitHub slug rules None
Auto heading IDs Lowercase concatenated Lowercase hyphenated Lowercase hyphenated Lowercase-hyphenated
Extra attributes (classes/ids) Limited MMD mechanisms IALs — very strong Limited Limited
See also
Next up: Previewing ▶
