Opening Files
Marked gives you options.
Live preview workflow
  1. Drag a Markdown file onto Marked (or use File Open… (+O)).
  2. Edit the file in your preferred editor.
  3. Save — Marked updates the preview automatically.
See Live Markdown Preview on Mac for vault watching, streaming preview, and editor-specific guides.
Drag to Dock Icon
The easiest way to use Marked on a file you’re already editing is to drag the document icon from the toolbar of your editor or from Finder to the Marked icon in your Dock. Marked will immediately start tracking any Markdown file (or text file) dropped on it. You can also drag files directly from the Finder.
Using the Menu
You can, of course, open Markdown files directly using the File Open… (+O) menu option. Marked works fine without a text editor, too. You can preview and convert your Markdown with just a click.
Marked can also open .rtf and .rtfd files directly (for example exports from Pages or TextEdit). They are converted to Markdown for preview and update when you save in the original app. See RTF and RTFD Support for details, including images and limitations.
Marked can open .pdf files the same way: conversion runs in the background, then the preview updates when finished. This works best for shorter, text-based PDFs; large manuals and scanned documents are slower and less accurate. See PDF Support for details and limitations.
From the Clipboard
If you have compatible (e.g. Markdown) text in your clipboard, you can open an instant preview by selecting File New Clipboard Preview (++V). If you copied a selection from a web browser or other app that put HTML or RTF on the clipboard, Marked converts it to Markdown for preview. When you paste RTF from an app like TextEdit or Pages, larger font sizes are roughly converted to heading levels (e.g. very large text becomes a level 1 heading, smaller large text becomes level 2, and so on). You can have multiple clipboard previews open at once, and you can save them to a new file by choosing File Save Clipboard Preview.
Creating a New Document
Marked allows you to create a new, empty text file with the File New (+N) command. It will immediately ask you for a location to save the file, and you can enable the “Edit new files automatically” option in the Marked Settings, Apps pane, next to the Text editor button to automatically open the newly-created file in your default editor.
Open Recent
Marked keeps track of recent documents, too. The File Open Recent menu option will show you the files you”ve had open and let you jump back to them. You can quickly re-open the last file you were viewing with ++R. Use ++P or Quick Actions to run menu and preview commands from the keyboard. There are a lot of other keyboard shortcuts, too. If you care to learn them, you can find a chart under Keyboard Shortcuts.
Quick Open
You can quickly switch between open documents, open recent documents, or open the File->Open dialog with the Quick Open panel (++O).
Next up: Using the Browser Extensions
