Kramdown Specification
Check out the Markdown Dingus to experiment with the Kramdown processor.
What is Kramdown?
Kramdown is a fast, pure-Ruby Markdown-superset converter that extends the original Markdown syntax with features found in other implementations like Maruku, PHP Markdown Extra, and Pandoc. It provides a strict syntax with definite rules while maintaining compatibility with most Markdown documents.
Key Characteristics
- Fast and Pure Ruby: Written entirely in Ruby for performance and portability
- Strict Syntax: Provides definite rules and clear specifications
- Enhanced Features: Includes many extensions not found in standard Markdown
- Jekyll Integration: Default Markdown processor for Jekyll static site generator
- Comprehensive: Supports both block-level and span-level elements with extensive customization
Major Differences from Standard Markdown
1. Enhanced Block-Level Elements
Definition Lists
- Kramdown supports definition lists (not in standard Markdown)
Uses
:to separate terms from definitions
Term 1
: Definition 1
Term 2
: Definition 2a
: Definition 2b
Tables
- Full table support with headers, alignment, and formatting
- More comprehensive than basic Markdown table syntax
| Header 1 | Header 2 | Header 3 |
| Left | Center | Right |
| Aligned | Aligned | Aligned |
Math Blocks
- Support for mathematical expressions using LaTeX syntax
- Both inline and block math support
Inline math: $E = mc^2$
Block math:
\int_{-\infty}^{\infty} e^{-x^2} dx = \sqrt{\pi}
2. Advanced Text Markup
Footnotes
- Full footnote support with automatic numbering
Reference-style footnotes with
[^1]syntax
This is a sentence with a footnote[^1].
[^1]: This is the footnote content.
Abbreviations
- Support for HTML-style abbreviations
- Automatic expansion of defined abbreviations
This uses HTML and CSS.
Typographic Symbols
- Automatic conversion of common typographic characters
- Smart quotes, em dashes, ellipses, etc.
"Smart quotes" and -- em dashes -- and ... ellipses
Even << guillemets >>
3. Attribute Lists and Extensions
Attribute List Definitions (ALDs)
- Define reusable attribute sets
- Support for IDs, classes, and custom attributes
A paragraph with attributes.
{: #para-one .highlight}
Inline Attribute Lists (IALs)
- Attach attributes to specific elements
- Both block-level and span-level support
This *is*{:.underline} some `code`{:#id}{:.class}.
A [link](test.html){:rel='something'} and some **tools**{:.tools}.
Extensions
- Custom extension system for additional functionality
- Built-in extensions for comments and options
{::comment}
This text is completely ignored by kramdown.
{:/comment}
{::options key="val" /}
4. Enhanced Code Block Support
Language Specification
Automatic syntax highlighting for fenced code blocks
Support for many programming languages
def hello puts "Hello, World!" end
Standard Code Blocks
- Improved handling of indented code blocks
- Better integration with other block elements
5. Stricter Parsing Rules
Line Wrapping
- Support for hard-wrapped content (lazy syntax)
- Clear rules for when line wrapping is allowed
- Not recommended for readability but supported for compatibility
Tab Handling
- Assumes tab stops at multiples of four
- Tabs only allowed at beginning of lines for indentation
- Must not be preceded by spaces
Block Boundaries
- Clear rules for when elements must start/end on block boundaries
- Consistent behavior across different element types
6. Advanced Link and Image Support
Automatic Links
- Enhanced automatic link detection
- Better handling of URLs and email addresses
Reference Links
- Improved reference link processing
- Better conflict resolution for multiple definitions
Image Attributes
- Support for image attributes through IALs
- Width, height, alt text, and other HTML attributes
{:width="300" height="200" class="responsive"}
7. HTML Integration
HTML Blocks
- Better handling of HTML within Markdown
- Support for HTML attributes and processing
- More flexible than standard Markdown HTML handling
HTML Spans
- Inline HTML with attribute support
- Better integration with Markdown syntax
8. Mathematical Expressions
Inline Math
$...$syntax for inline mathematical expressions - LaTeX-compatible syntax
Block Math
$$...$$syntax for block mathematical expressions - Support for complex equations and formulas
Kramdown vs Other Markdown Flavors
| Feature | Kramdown | CommonMark (GFM) | GitHub Flavored | MultiMarkdown | Standard |
| Strikethrough | No | Yes | No | No | No |
| Task Lists | No | No | Yes | Yes | No |
| Fenced Code | Yes | Yes | Yes | Yes | No |
| Math | Yes | No | Yes | Yes | No |
| Footnotes | Yes | Yes | Yes | Yes | No |
| Definition Lists | Yes | No | No | Yes | No |
| Abbreviations | Yes | No | No | No | No |
| Attribute Lists | Yes | No | No | No | No |
| Typography | Yes | No | No | Yes | No |
Key Advantages of Kramdown
- Comprehensive Feature Set: Includes many extensions not found in other implementations
- Jekyll Integration: Seamless integration with Jekyll static site generator
- Ruby Ecosystem: Pure Ruby implementation with good Ruby tooling support
- Extensibility: Custom extension system for additional functionality
- Attribute Support: Rich attribute system for HTML output customization
- Mathematical Support: Built-in support for LaTeX math expressions
- Strict Parsing: Clear, unambiguous parsing rules
Common Use Cases
Jekyll Sites
- Default processor for Jekyll static site generation
- Excellent for documentation and blog sites
Technical Documentation
- Math support for scientific and technical writing
- Attribute lists for advanced HTML customization
Academic Writing
- Footnote support for citations and references
- Mathematical expressions for formulas and equations
Content Management
- Extensions for custom functionality
- Attribute lists for metadata and styling
Resources
- Kramdown Syntax Documentation
- Kramdown Converter Documentation
- Jekyll Integration Guide
- Kramdown GitHub Repository
Migration from Standard Markdown
Most standard Markdown documents work with Kramdown without modification. To take advantage of Kramdown’s features:
- Add Definition Lists: Convert glossaries and term lists
- Use Attribute Lists: Add IDs, classes, and custom attributes
- Implement Footnotes: Convert parenthetical references
Best Practices
- Avoid Lazy Syntax: Don’t rely on hard-wrapping for readability
- Use Attribute Lists: Leverage IALs for styling and metadata
- Consistent Indentation: Use spaces instead of tabs when possible
This documentation covers Kramdown 2.5.1. For the most current information, always refer to the official documentation at kramdown.gettalong.org.
