Embedding Mind Maps andĀ Outlines
Mind maps and outlines can be embedded in your Markdown preview using Marked’s include syntax or the IA Writer block syntax. Behavior depends on the file format and the per-format checkboxes under Embed as Mermaid mind maps: in Marked Settings, Apps pane (Mind Maps and Outlines).
SupportedĀ Formats
iThoughtsĀ XĀ (.itmz)
iThoughts mind map files are zip archives containing map data and an optional preview image.
MindManagerĀ (.mmap)
MindManager files are zip archives containing Document.xml. Unzipped MindManager packages (a folder containing Document.xml) and direct paths to Document.xml are also supported.
FreeMindĀ (.mm)
FreeMind mind map files use the .mm extension and store data as XML. Marked detects FreeMind format by checking that the file content starts with <map; if not (e.g., a code snippet), the file is included as plain text. FreeMind files are supported for Mermaid mind map embedding.
OPMLĀ (.opml)
OPML (Outline Processor Markup Language) is an XML format for hierarchical outlines, widely used by outliners and feed readers. iThoughts and other apps can export to OPML. Marked converts included OPML files to Mermaid mind map diagrams.
BikeĀ (.bike)
See Bike for opening a .bike file. Included Bike outlines follow the Bike outlines checkbox: on renders a Mermaid mind map (the file name, without .bike, is the root node); off renders a nested Markdown list with no document title.
OmniOutliner (.ooutline)
OmniOutliner outlines can be included the same way. The OmniOutliner outlines checkbox under Embed as Mermaid mind maps: controls Mermaid vs Markdown list rendering. Opening an OmniOutliner file is covered in OmniOutliner and OPML.
Tree OutlinerĀ (.treeoutline)
See Tree Outliner. The Tree Outliner outlines checkbox controls both opening a .treeoutline file and including one. On renders a Mermaid mind map rooted at the document title. Off compiles headings and lists, using Headings through level in the Tree Outliner group.
Embed as MermaidĀ mindĀ maps
In Marked Settings, Apps pane, under Mind Maps and Outlines, the group Embed as Mermaid mind maps: has one checkbox per format:
When a format’s checkbox is enabled (the default for supported formats), Marked converts included files of that type to Mermaid diagrams:
iThoughts, MindManager, FreeMind, OPML, Bike, OmniOutliner, and Tree Outliner — Rendered as Mermaid mindmap diagrams with the tidy-tree layout. For iThoughts and MindManager, shape information (rounded, rectangle, hexagon, etc.) is preserved where available. FreeMind (.mm) and OPML use the same mind map format. Bike (.bike) outlines use the included filename (minus extension) as the mind map root node. Tree Outliner uses the document title as the root. Node labels are plain text (links become link text; tasks show as ☐ / ā˜‘ prefixes). Mermaid is included by default in every Markdown preview.
When a format’s checkbox is disabled:
  • iThoughts — The built-in preview image (preview.png) from the .itmz file is embedded as a base64 image. The image alt text uses the filename.
  • MindManager — The outline is embedded as a nested Markdown list.
  • FreeMind — The outline is embedded as a nested Markdown list.
  • OPML — The outline is embedded as a nested Markdown list (no mind map).
  • Bike — The outline is embedded as a nested Markdown list (no document title). Heading rows are bold, and tasks become GitHub checkboxes. See Bike.
  • OmniOutliner — The outline is embedded as a nested Markdown list/checklist.
  • Tree Outliner — The outline is compiled to Markdown headings and lists. The document title is heading 1, and Headings through level sets how deep headings go. See Tree Outliner.
IncludeĀ Syntax
Use the same syntax as for other file includes:
<<[path/to/map.itmz]
<<[path/to/map.mmap]
<<[path/to/map.mm]
<<[path/to/outline.opml]
<<[path/to/outline.bike]
<<[path/to/outline.treeoutline]
Or with iA Writer block syntax:
/path/to/map.itmz
Paths can be relative to the main document or absolute (starting with / or ~). See Multi-File Documents for details.
OPMLĀ Conversion
OPML files use nested <outline> elements with a text attribute. When OPML files is enabled under Embed as Mermaid mind maps: (see Settings: Apps), conversion produces a Mermaid mind map using the same format as iThoughts and MindManager:
  • Child outlines of <body> become the top level (or children of an ā€œOutlineā€ root if there are multiple top-level items)
  • Nested outlines define the hierarchy
  • Missing or empty text is shown as (unnamed)
  • Text is sanitized; special characters are escaped for Mermaid
BikeĀ Conversion
Bike .bike files are HTML with a root <ul> and <li> items. In list mode, every row is a list item: data-type="heading" rows are bold, and data-type="task" rows are GitHub checkboxes (completed when data-done has a timestamp, or data-checked / data-completed is true). Inline formatting and links in node text are converted to Markdown. Opening a .bike file always uses this list. When an included file is embedded as a Mermaid mind map, the file name (minus extension) is the single root node and labels are plain text formatted for Mermaid mindmap syntax.
Next up: Keyboard Shortcuts ā–¶
