TheĀ Archive
The Archive maintains your notes as files on disk and can mirror the note you are editing straight into Markedās streaming preview channel.
Stream PreviewĀ toĀ Marked
- In Marked, open (or reuse an existing streaming preview window).
- Switch to The Archive and choose Note ā Stream Preview to Marked so The Archive activates Marked and begins sending the frontmost note text.
Marked updates as you type in The Archive, following the same mkStreamingPreview clipboard contract as other integrated appsāsee Technical details under Streaming Preview.
If previews look out of date, confirm the streaming window is still frontmost in Marked and toggle the Archive menu command once.
