URL Handler
Marked’s URL handler provides additional scripting and workflow capabilities. You can include a url in the notes of another application, for example, that will open a file in Marked when clicked. You can perform several actions, as listed below.
The URL scheme
Marked’s URL scheme is x-marked, called with options like x-marked://open?file=/Users/username/Desktop/report.md.
You can specifically target Marked 3 by using x-marked-3 instead of x-marked. The methods and parameters are exactly the same as x-marked, but only Marked 3 will respond to x-marked-3.
Calling from the command line/scripts
Calling the url handler from the command line or a script can be done using the macOS open command:
open 'x-marked://open?file=filename.md'
open 'x-marked://refresh?file=filename.md'
Calling in the background
You can call the open command with the -g flag to perform the result in the background without switching focus. To perform the command in the background and raise the window to the top without stealing focus:
open -g 'x-marked://open?file=filename.md&raise=true'
Optional parameters
x-success
Any command can provide an x-success query parameter. Set this to a url to be called after performing the command. For example: x-marked://open/?file=filename.md&x-success=ithoughts:. You can also provide a bundle identifier (such as com.googlecode.iterm) to open an application that doesn’t have a URL scheme.
raise
A raise parameter can be passed with any command that accepts a file parameter or affects all windows. After the action is performed, the affected window(s) will raise above all other windows (all applications) before returning or executing a callback.
"x-marked://refresh?file=filename.md&raise=true"
speedread
A speedread parameter can be passed with URL handler commands that open a preview document (open, paste, preview, and stream). Set speedread=1 to automatically start Speed Read as soon as the target preview is ready.
Examples:
x-marked://open?file=/Users/username/Desktop/report.md&speedread=1
x-marked://preview?text=Some%20text&speedread=1
x-marked://paste?speedread=1
Available commands
The following commands are available to the x-marked URL handler.
addstyle
Add a new custom style to Marked.
Parameters:
css: URL encoded CSS text to write to a custom style. Required unless passing a file parameter.
file: Full path (POSIX) to a CSS file to add to Marked. Required unless passing a css parameter.
name: The name of the style to generate.
With the css parameter, this will be used as both the filename when writing to disk, with “.css” added, and the menu item name. It’s required for css parameter, and optional for file (filename will be used as if the name parameter is empty).
x-marked://addstyle?name=My+new+style&css=...
x-marked://addstyle?file=/Users/myuser/Custom+Styles/Unicorn.css
If you include a name with the file parameter, the menu item will get that name instead of the filename. If you use the same name again with a different path, the menu item will be updated with the new path rather than adding a second item with the same name.
defaults
Set user Settings. Accepts a list of keys and values as query parameters. Only existing keys will be set. If the preference change requires a refresh, all windows will refresh automatically unless refresh=0 is passed.
Use 1 for true and 0 for false on boolean values.
Parameters:
refresh (optional): if set to 0, automatic refresh of open preview windows is disabled
  • Default: 1 (true)
Example:
x-marked://defaults?syntaxHighlight=1&includeMathJax=0
The defaults method is mostly designed so that the developer can add links to esoteric features that might not otherwise be available in Settings. There might be some standard options you’d want to toggle when automating, though. Some common Settings you might want to control during automation:
syntaxHighlight
enable or disable syntax highlighting
includeMathJax
enable or disable internal MathJax handling
processor
set to multimarkdown or mmd to change the processor to MultiMarkdown, discount or gfm to use the Discount processor
h1IsPageBreak, h2IsPageBreak, breakBeforeFootnotes
Automatic page breaks in export before header levels 1 and 2, and footnotes.
dingus
Open the Markdown Dingus for testing different Markdown processors.
x-marked://dingus
Parameters:
processor (optional): Specify which processor to select by default. Valid values:
  • multimarkdown - MultiMarkdown processor
  • commonmark - CommonMark (GFM) processor
  • discount or discount (gfm) - Discount processor
  • kramdown - Kramdown processor
Examples:
  • x-marked://dingus?processor=kramdown - Opens with Kramdown selected
  • x-marked://dingus?processor=commonmark - Opens with CommonMark (GFM) selected
Note: This opens the Markdown Dingus window, which allows you to test and compare different Markdown processors (MultiMarkdown, CommonMark (GFM), Discount, and Kramdown) side by side. Perfect for experimenting with Markdown syntax and understanding processor differences.
stylestealer / steal
Open the Style Stealer HUD. Useful when you want to capture CSS from a live page or run a manual content extraction session without launching it through the UI.
Synonyms: x-marked://stylestealer … , x-marked://steal …
Parameters:
url (optional): A URL to pre-populate in the Style Stealer window. If omitted the HUD opens blank.
Examples:
  • x-marked://stylestealer?url=https%3A%2F%2Fmarkedapp.com
  • x-marked://steal/https:%2F%2Fexample.com
importurl / markdownify
Open the “Import URL” (Content Extractor) window so you can run the Markdownifier pipeline manually. This does not perform the extraction automatically — that is handled by the extract command below.
Synonyms: x-marked://importurl … , x-marked://markdownify …
Parameters:
url (optional): Prefills the Import URL field. If omitted the window opens with an empty field waiting for you to paste a link. html (optional, markdownify only): When provided on x-marked://markdownify, this should be URL-encoded raw HTML. Marked will convert the HTML to Markdown using the same rules as Clipboard Preview and open it in a transient document, as if you had pasted that HTML into a Clipboard Preview window.
Examples:
  • x-marked://importurl?url=https%3A%2F%2Fexample.com%2Farticle
  • x-marked://markdownify/https:%2F%2Fnews.ycombinator.com
do
Run a JavaScript command in a document window. Marked’s entire JavaScript API is documented here.
Parameters:
js (required): query string containing a JavaScript command
  • Accepts path parameters referencing names of files, or “all”
  • Paths split by / will search multiple files
  • Partial filenames will complete best match
      x-marked://do/filename1/filename2?js=...
      x-marked://do/all?js=...
file: query parameter containing comma-separated paths/filenames
x-marked://do?file=filename1,filename2&js=...
Will operate on frontmost window if a filename is not given (or “all” is not passed)
help
Open the Marked internal help system, optionally specifying a topic. This is primarily for use internally, but accessible via URL. A url to any given section can be copied by right clicking on the bookmark icon to the right of a headline and selecting Copy Link. Marked 3 in-app help and search use the x-marked-3 scheme for these links so macOS opens them in Marked 3 when Marked 2 is also installed; the examples below use that form.
dingus
x-marked://dingus
######## Parameters:
Examples:
Parameters:
page (optional): The exact title of an existing page, with optional anchor hash
x-marked-3://help?page=Document_Statistics
Spaces are replaced with underscores, per the Marked help file naming convention. A colon (:) may be used in place of a hash (#) when specifying an anchor.
The target may be specified by path alone (without query string):
x-marked-3://help/Keyword_Highlighting:editingkeywords
extract
Extract content from a web URL and open it as a new document in Marked.
x-marked://extract?url=https://example.com
Parameters:
url (required): The web URL to extract content from. Must start with http:// or https://
window (optional): Name for the window
id (optional): Namespace identifier
base (optional): Base URL for relative links
raise (optional): Set to true to raise the window after opening
manual (optional): Set to true to open the Style Stealer manual extraction window instead of performing automatic extraction.
  • When manual=true, Marked opens the Style Stealer, pre-fills the URL field (if provided), suppresses any automatic Open dialog, and lets you interactively select and extract styles/content before saving.
  • When omitted or false, Marked runs the automatic extractor (Markdownifier) and opens the result directly as a new temporary document.
Examples:
x-marked://extract?url=https://news.ycombinator.com
x-marked://extract?url=https://github.com&window=GitHub&raise=true
x-marked://extract?url=https://example.com/article&manual=true
x-marked://extract?url=https://blog.example.com/post-title
Note: This command uses Marked’s content extraction service to fetch web pages, extract clean content using Readability, convert to Markdown format, and open the result in a new temporary document. The extracted content includes metadata (title, source URL, date) and is formatted as clean Markdown. Perfect for quickly capturing and editing web content.
open
Opens the specified document in Marked.
Parameters:
file (required): The full POSIX path to the document to be opened, or a comma-separated list of paths. Commas inside a filename are allowed; Marked only treats a comma as a multi-file separator when it follows a file extension (for example .md,) or when the next path starts with / or ~.
speedread (optional): Set to 1 to start Speed Read automatically after opening.
open also accepts a path whose components will be combined into a single url
x-marked://open/~/nvALT2.2
If the file path provided doesn’t exist or can’t be opened, Marked will still come to the forefront. Running without the file parameter or with a blank value will simply open Marked.
Marked will also open files if only the path of a file is called on the URL handler, e.g. x-marked:///Users/username/Desktop/report.md.
paste
Create a new document from the current contents of the clipboard.
x-marked://paste
Parameters:
speedread (optional): Set to 1 to start Speed Read automatically after opening the clipboard preview.
Note: This creates a temporary document using the “Preview Clipboard” command. Any text in your clipboard is added to a new, blank document, which is then opened in Marked. If closed without saving, it’s discarded.
preview
Preview specified text in a new document.
x-marked://preview?text=Some%20text%20to%20%2A%2Apreview%2A%2A%0A
Parameters:
text (required): The text to insert into the preview. Percent-encoded text will be unencoded prior to viewing the document.
speedread (optional): Set to 1 to start Speed Read automatically after opening the preview text.
stream
Open a streaming clipboard preview window.
x-marked://stream
Parameters:
speedread (optional): Set to 1 to start Speed Read automatically after opening the streaming preview.
Note: This creates a temporary document using the “Preview Clipboard” command. The passed text is added to a new, blank document, which is then opened in Marked. If closed without saving, it’s discarded.
refresh
Refresh a document preview or all open previews.
Parameters:
file: query parameter containing comma-separated paths/filenames (files must be currently open in Marked). Calling with no file parameter or ?file=all will refresh all open windows.
The file parameter can be partial, Marked will refresh all open windows with a partial match in the filename (not the full path). Passing “all” will refresh all windows.
x-marked://refresh
x-marked://refresh?file=/Users/username/Desktop/report.md
x-marked://refresh?file=report.md
If called with no file parameter but document paths specified in the url, paths split by / will search multiple files, and partial filenames will complete the best match.
x-marked://refresh/filename1/filename2
style
Set the preview style (CSS) for one or more documents.
Parameters:
css (required): query string containing the name or path of a style. Styles must be present in Marked’s style menu as default or manually-added custom styles.
      x-marked://style/filename1/filename2?css=...
      x-marked://style/all?css=...
x-marked://style?file=filename1,filename2&css=...
This method will operate on the frontmost window if a filename is not given (or “all” is not passed).
Next up: AppleScript Support ▶
