Command Line Utility
The mk command-line tool provides easy access to Marked’s features from the terminal, enabling workflow automation and integration with shell scripts and other command-line tools.
Installation
The recommended way to install mk is with Homebrew:
brew tap ttscoff/thelab
brew install ttscoff/thelab/mk
If you do not use Homebrew, download and install the signed package:
⇩ Download
Signed PKG installer for mk. Double-click to launch Installer and follow the prompts.
After downloading mk.pkg, double-click it and follow the installer prompts.
Basic Usage
Opening Files
Open a markdown file in Marked from the command line:
mk file.md
mk ~/Documents/notes.md
mk --raise document.md  # Open and raise window above all others
Streaming Content from STDIN
Stream content directly to Marked’s Streaming Preview:
echo "# Hello World" | mk
cat notes.md | mk
mk -  # Explicitly use STDIN
The Streaming Preview window will open and display the content in real-time as it’s piped from other commands.
Command Reference
File Operations
mk [file] — Open a markdown file in Marked
mk [file] --raise — Open file and raise the window above all others
STDIN and Streaming
mk or mk - — Read from STDIN and open Streaming Preview
mk --stream — Open Streaming Preview window without reading STDIN
Preview Management
mk --refresh — Refresh the frontmost preview window
mk --refresh all — Refresh all open preview windows
mk --refresh file.md — Refresh the preview for a specific file (if open)
Preferences
mk --pref — Open Marked preferences (General page)
mk --pref Advanced — Open preferences to a specific page
mk --defaults KEY=VALUE [KEY=VALUE...] — Set user preferences (multiple pairs allowed)
mk --defaults syntaxHighlight=1 includeMathJax=0 processor=multimarkdown
Style Management
mk --style NAME — Set preview style for open windows
mk --add-style FILE — Add a CSS file as a custom style to Marked
mk --add-style ~/Styles/custom.css
JavaScript Execution
mk --dojs "JAVASCRIPT_COMMAND" — Run JavaScript in frontmost window
mk --dojs "SCRIPT" all — Run JavaScript in all windows
mk --dojs "SCRIPT" file.md — Run JavaScript in specific file(s)
mk --dojs "window.scrollTo(0,0)"
mk --dojs "alert('Hello')" all
Content Extraction and Import
mk --extract URL — Extract content from URL and open in Marked
mk --extract https://example.com/article
mk --importurl [URL] — Open Import URL window (optionally with URL)
mk --stylestealer [URL] — Open Style Stealer HUD (optionally with URL)
Utility Commands
mk --paste — Create new document from clipboard
mk --preview TEXT — Preview text directly in a new document
mk --dingus — Open Markdown Dingus for testing processors
mk --help or mk -h — Show usage information
mk --version or mk -v — Show version information
Examples
# Open a file
mk document.md
# Stream markdown from a file
cat notes.md | mk
# Process and preview
grep -i "important" notes.md | mk
# Refresh all previews
mk --refresh all
# Add a custom style
mk --add-style ~/Documents/MyTheme.css
# Set preferences
mk --defaults syntaxHighlight=1 processor=multimarkdown
# Run JavaScript in all windows
mk --dojs "window.scrollTo(0,0)" all
# Extract content from a webpage
mk --extract https://blog.example.com/article
# Preview text directly
mk --preview "## Hello\n\nThis is **markdown** text!"
Integration
Shell Aliases
Add to your ~/.zshrc or ~/.bash_profile:
alias mko='mk --raise'      # Open with raise
alias mkr='mk --refresh all' # Refresh all
Scripts
Use mk in shell scripts for automation:
#!/bin/bash
# Watch a file and stream changes to Marked
fswatch -o document.md | while read; do
  cat document.md | mk
done
Workflows
Combine with other tools:
# Convert clipboard to markdown and preview
pbpaste | markdown | mk
# Search and preview
grep -r "TODO" . | head -20 | mk
Open Source
The mk command-line tool is open source and available on GitHub:
https://github.com/ttscoff/mk
You can:
  • View the source code
  • Contribute improvements
  • Report issues
  • Build from source if needed
The tool is written in Swift and can be compiled using Xcode. See the README for build instructions.
Version
Check your installed mk version with:
mk --version
Related Features
Next up: Streaming Preview
