Settings: Style
Options in the :
Layout and typography
- Limit text width in Preview
- Set a maximum width for the body of the preview using the slider (in pixels).
- Auto-hyphenate in paragraphs
- Allow words to break with hyphenation automatically.
- Prevent widows in headlines and paragraphs
- Forces a non-breaking space between the last two words of headlines and paragraphs to prevent single words from wrapping to a new line.
- Generate typographically correct quotes and punctuation
- Use SmartyPants for smart quotes, ellipses conversion, and other typography features (MultiMarkdown).
- Surround footnotes markers with square brackets
- If checked, use the default MultiMarkdown formatting for footnote markers ([1]). Uncheck to strip square brackets.
- Enable Outline for extensions
- Automatically turn on Outline mode for files with listed extensions.
- Use APA Style
- Use APA style outlines instead of the default Decimal format.
- Style verbatim (code) blocks as poetry
- If checked, tab-indented, fenced or included code is displayed as poetry instead of a code block (no syntax highlighting, and special styling depending on the theme).
- Allow themes to wrap text inside code blocks
If checked, themes are allowed to cause wrapping within
pre>codeblocks. If unchecked, horizontal overflow will always scroll.
- Always wrap code
- Force code blocks to wrap regardless of theme settings (overrides theme wrapping behavior).
- Detect and style RTL text
- Detect the language of each element and set its text direction to right-to-left (RTL) when needed.
Theme
- Manage Styles
Opens the Style Manager window. Add CSS files from your drive to have them appear in Style picker menus. Use the
Add New Stylebutton or drag CSS files to this window. Drag to reorder, and use the checkboxes to enable or disable Styles.
- More Themes
- Open the online theme gallery to browse and install additional styles.
- Default style
- The style selected here will be loaded for all new windows, unless a document-specific style is indicated in metadata (e.g. “Marked Style: Grump”).
- Track CSS changes
- When this is enabled, Marked will watch the current Style for disk changes, aiding in custom style editing and web development.
- Additional CSS
- CSS added here is appended after the normal stylesheet for every theme. It is a partial overlay, not a full theme substitute.
Marked rewrites selectors in this field (for example, print rules should use
body.mkprinting #wrapper …). There is no size or validity gate — see Creating Custom CSS. - This applies to all documents and all styles, including HTML export when styles are included. If you want to apply custom CSS to documents based on conditions, use Custom Rules under .
Include Scripts
- Syntax Highlighting
- Turn on highlight.js syntax highlighting for code blocks. Select a theme from the dropdown.
- If Only if language specified is checked, syntax highlighting will only be applied to fenced code blocks with a language specified.
Show line numbers in code blocks — when syntax highlighting is on, display line numbers on highlighted blocks (with per-block
linenums/nolinenumsoverrides).
- Enable MathJax
- Loads MathJax for displaying MathML equations. Choose Local (bundled) or CDN from the dropdown.
- Additional Packages opens a sheet to include extra MathJax packages (for example Physics and Chemistry).
- Advanced Configuration opens a sheet for custom MathJax configuration.
- Enable KaTeX
- Loads KaTeX as an alternative to MathJax. Only one or the other may be selected.
- Number equations
- If applicable, Marked will add figure numbers to rendered equations. Choose Left Side or Right Side for numbering. If using MathJax, you can choose AMS only to number only AMS equations.
- Mermaid
- Loads mermaid.js from a CDN to enable Markdown-style diagramming. The hook required to render Mermaid diagrams on every document update is included automatically.
- Pan and zoom diagrams
- When Mermaid diagrams are present, enable zoom with ⌘-scroll and pan by clicking and dragging.
