Layout and Typography
Marked provides defaults for improving typography and export layout, as well as offering finite control over the options if you need more customization.
Typography
Hyphenation and widows
The Auto-hyphenate in paragraphs option allows Marked to determine where a line would best be hyphenated to improve the “rag” of a paragraph. This is most useful when using a style with justified alignment, but can improve reading flow in longer paragraphs as well.
The Prevent widows in headlines and paragraphs option, if enabled, will force breaks in headlines and paragraphs to prevent single, short words from ending up on a line by themselves.
Marked automatically connects headlines with the following element, to prevent orphaned headlines when exporting to a paginated format (PDF, print).
Punctuation marks
If your processor is set to MultiMarkdown, you’ll have the option to enable or disable “smart punctuation” using the Generate typographically correct quotes and punctuation option. If enabled, paired double and single quotes will be turned into “curly” quotes, apostrophes will be replaced with typographically correct symbols, and other automatic adjustments are performed.
Footnote markers
In the Layout and Typography section of the Marked Settings, Style pane, Surround footnote markers with square brackets is enabled by default when using the MultiMarkdown processor, and creates footnote markers within the document which are surrounded by square brackets (e.g. “[1]”). To disable the creation of the square brackets, uncheck this option.
Outline mode
Outline mode will display any file containing a hierarchical series of headers as an APA or decimal outline. The default is APA style, but this can be toggled off.
In the Marked Settings, Style pane under “Layout and typography,” you can add filename extensions for which Outline mode is automatically enabled. This is especially useful for OPML and supported mind map files (such as iThoughtsX and MindNode). The extension should be only the alphanumeric portion of the filename appearing after the last dot character.
Toggle the default outline mode with the Use APA Style checkbox. This can be toggled temporarily from the Gear menu of a document window.
Poetry
The Style verbatim code blocks as poetry option in the Marked Settings, Style pane will cause blocks indented by 4 or more spaces to display using the theme’s “poetry” styling. This is usually a non-syntax-highlighted, italicized section.
Line breaks are preserved in these blocks by default, so it provides an easy way to incorporate poetry and lyrical sections into a document that doesn’t have other need for code blocks.
This setting adds a “poetry” body class that can be used in custom themes to style code blocks and other elements when “poetry mode” is enabled.
Code block wrapping
The Allow themes to wrap text inside code blocks lets the Preview Style determine how to format code blocks. Disabling this option forces all code blocks to scroll horizontal overflow rather than wrapping it, regardless of the current preview style.
Working full screen
When using Marked in full screen mode (Control-Command-F), you may want to limit the width of displayed text to create a centered column of readable content. The Limit text width in Preview checkbox will enable a slider with which you can define the maximum width of the displayed content. This affects non-full-screen display as well.
Next up: Document Statistics
