Settings: Processor
Options in the Marked Settings, Processor pane:
Settings: Processor
Settings: Processor
Process Markdown with
Default Markdown processor. The CommonMark processor is preferred for GitHub users, MultiMarkdown is ideal for writers, and Discount and Kramdown have specialized purposes. Apex (beta) covers the features people usually pick CommonMark, GitHub Flavored Markdown, MultiMarkdown, or Kramdown for. See Apex (beta). Marked compensates for some differences between syntax. See Help->Markdown Reference for additional information.
Custom Rules
Click the Custom Rules button to open the Rules Editor, where you can specify different processors and document transformations to run based on matching criteria. See Custom Processor for details.
New documents use custom
When checked, new documents automatically use your saved preprocessor and/or processor from Custom Rules without requiring per-document setup.
Full Disk Access
Click Grant to give Marked permission to read files outside its sandbox when using custom processors or other features that need broader file access.
Configure Apex
When Apex (beta) is the default processor, click Configure Apex to set syntax, citation files, and index options. See Apex configuration.
To explore the differences between the processors, check out the Markdown Dingus.
HTML
Generate IDs on headlines
Generate header IDs based on contents of h1-h6 tag.
Use random footnote IDs
Generate random footnote IDs to avoid conflicts when multiple documents are displayed on one page.
Process Markdown inside of HTML
By default, Markdown inside of HTML tags is usually ignored. This option forces Marked to continue processing within block elements. Note that some markup may cause issues.
Rendering
Retain line breaks in paragraphs
Respect line breaks in paragraph text, replacing with hard breaks instead of concatenating with the previous line.
Render GitHub checkboxes
Render - [ ] and - [x] for creating checkboxes in lists. Checkboxes are rendered for preview but not functional within Marked.
Render GitHub :emoji:
Render :name: shortcodes as GitHub-style emoji in the preview.
#Text is tag
Allows hashtags (# immediately followed by text with no space) to be interpreted as tags, not headlines. This functionality is default for Bear users.
Style tags
When #Text is tag is enabled, display recognized tags with capsule styling. Tags can be shown or hidden from ⚙ Proofing Show Comments.
#Text is tag enabled
Render ==highlight== and ~~delete~~
If this option is enabled, then ==highlight== text will be rendered as an HTML <mark> tag, which will appear as a yellow highlight unless otherwise modified by a Style. Additionally, ~~delete~~ syntax will be rendered with a <del> tag.
If Render as CriticMarkup is enabled, then ==highlight== and ~~delete~~ syntax will be converted to CriticMarkup, which can then be displayed in original, markup, and edited views.
Render ~text~ as underscore
If this option is enabled, ~text~ surrounded by single tildes will be rendered as underlined. This conflicts with MultiMarkdown syntax for subscript and is disabled by default.
Treat +++ as page breaks
When enabled, a line of three or more + characters is treated as a page break (same as <!--BREAK-->). Compatible with iA Writer. Off by default.
Remove iA Writer annotations
When enabled, Marked removes the iA Writer annotations block at the end of a file before preview. That block is an Annotations: line containing a SHA-256 hash, then @name and &name range lines, often with a lone --- just above it. Off by default. If ordinary prose follows the Annotations: line, the file is left unchanged.
iA Writer compatibility
When enabled, Marked supports iA Writer content blocks. A line that starts with / followed by a file path (up to three leading spaces allowed) includes that file: text and Markdown files are inserted, code files become code blocks, and images are displayed. An optional title can follow the path in quotes or parentheses. A line containing only an image URL displays the image. Lines inside fenced code blocks and <pre> blocks are never converted. Turn this off if lines that begin with a path are being replaced unexpectedly. On by default.
Next up: Settings: Applications ▶
