Discount GFMÂ Specification
Check out the Markdown Dingus to experiment with the Discount processor.
What is Discount GFM?
Discount GFM (GitHub Flavored Markdown) is a C-based Markdown processor that implements GitHubâs extended Markdown syntax. Itâs based on the original Discount library but enhanced with GitHub-specific features like tables, task lists, strikethrough text, and automatic URL linking.
Key Characteristics
- C-Based Performance: Fast, native C implementation for optimal performance
- GitHub Compatibility: Implements GitHubâs Markdown extensions for maximum compatibility
- Lightweight: Minimal dependencies and small footprint
- Extensible: Supports various Markdown extensions and custom options
- HTML5 Support: Generates modern HTML5 output with proper semantic markup
Major Differences from Standard Markdown
1. GitHub Flavored Markdown Extensions
Tables
- Full support for GitHub-style tables with alignment options
- Headers, separators, and data rows with proper HTML table structure
Column alignment using colons (
:) in separator rows
| Header 1 | Header 2 | Header 3 |
| Left | Center | Right |
| Aligned | Aligned | Aligned |
Task Lists
- Support for GitHub-style checkboxes in lists
- Interactive checkboxes (rendered as HTML input elements)
- Both checked and unchecked states supported
- [x] Completed task
- [ ] Pending task
- [x] Another completed task
Strikethrough Text
Text enclosed in double tildes (
~~) becomes strikethrough -
Uses HTML
<del>tags for semantic markup - Supports multiple tildes for emphasis
~~This text is crossed out~~
~~Mistaken text that should be removed~~
2. Enhanced Code Block Support
Fenced Code Blocks
Triple backticks (
```) for code blocks - Language specification for syntax highlighting
- No indentation required (unlike standard Markdown)
```javascript
function hello() {
console.log("Hello, World!");
**Automatic Language Detection**
- Support for many programming languages
- Proper [syntax highlighting](Features_For_Coders.html) when supported
- Fallback to plain text for unsupported languages
### 3. **Automatic URL Linking** [3-automatic-url-linking]
**URL Autolinking**
- Automatic conversion of URLs to clickable links
- Support for http, https, and ftp protocols
- Email addresses automatically converted to mailto links
```markdown
Visit http://example.com for more information.
Contact us at user@example.com
Smart Link Detection
- Recognizes URLs without explicit markup
- Handles various URL formats and protocols
- Configurable link safety options
4. Advanced List Features
Alphabetic Lists
- Ordered lists with alphabetic markers (a, b, c, etc.)
- Automatic progression through the alphabet
Proper HTML
<ol type="a">output
<!-- apex-alpha-list-lower -->
1. First item
2. Second item
3. Third item
Enhanced List Processing
- Better handling of nested lists
- Improved spacing and indentation
- Support for mixed list types
5. Footnotes Support
Reference-Style Footnotes
- Automatic footnote numbering
Reference links with
[^1]syntax - Footnote definitions at document end
This is a sentence with a footnote[^1].
[^1]: This is the footnote content.
Automatic Footnote Processing
- Generates proper HTML footnote structure
- Links between references and definitions
- Sequential numbering throughout document
6. HTMLÂ Integration
HTML5 Support
- Full HTML5 tag recognition
- Proper semantic markup generation
- Modern HTML structure and attributes
Raw HTML Blocks
- Support for HTML within Markdown
- Proper escaping and sanitization
- Integration with Markdown syntax
7. Enhanced Emphasis Rules
Relaxed Emphasis
Single underscores (
_) donât create emphasis in the middle of words - Better for documenting code and technical content
- Prevents unwanted emphasis in identifiers
This is a variable_name that won't be emphasized.
This is _emphasized text_ that will be styled.
Multiple Emphasis Levels
- Support for bold, italic, and combined emphasis
- Consistent with standard Markdown emphasis rules
Proper HTML output with
<strong>and<em>tags
8. Table of Contents Generation
Automatic TOC
- Generates table of contents from headings
- Hierarchical structure based on heading levels
- Configurable TOC generation options
Heading ID Generation
- Automatic ID generation for headings
- Anchor links for easy navigation
- Consistent ID formatting
Discount GFM vs Other Markdown Flavors
| Feature | Discount | CommonMark (GFM) | Kramdown | MultiMarkdown | Standard |
| Tables | Yes | No | Yes | Yes | No |
| Strikethrough | Yes | No | No | Yes | No |
| Task Lists | Yes | No | No | Yes | No |
| Fenced Code | Yes | Yes | Yes | Yes | No |
| Math | No | No | Yes | Yes | No |
| Footnotes | Yes | No | Yes | Yes | No |
| Definition Lists | No | No | Yes | Yes | No |
| Abbreviations | No | No | Yes | No | No |
| Attribute Lists | No | No | Yes | No | No |
| Extensions | Limited | No | Yes | Yes | No |
| Typography | Basic | No | Yes | No | No |
| Autolinks | Yes | No | No | No | No |
| Alphabetic Lists | Yes | No | No | No | No |
Key Advantages of Discount GFM
- GitHub Compatibility: Perfect for content that needs to work on GitHub
- Performance: Fast C-based implementation
- Simplicity: Focused on core GitHub features without complexity
- Reliability: Stable, well-tested implementation
- Standards Compliance: Follows GitHubâs Markdown specification
- Lightweight: Minimal resource usage and dependencies
Common Use Cases
GitHub Documentation
- README files and project documentation
- GitHub Pages and wikis
- Issue and pull request descriptions
Technical Writing
- Code documentation and tutorials
- API documentation
- Technical specifications
Content Management
- Blog posts and articles
- Documentation websites
- Knowledge bases
Collaborative Editing
- Team documentation
- Project planning documents
- Meeting notes and minutes
Configuration Options
Discount GFM supports various configuration options:
- Auto-linking: Enable/disable automatic URL detection
- Footnotes: Control footnote processing
- Table of Contents: TOC generation settings
- HTML Safety: Link validation and sanitization
- Strict Mode: Enhanced parsing rules
- Smart Quotes: Automatic quote conversion
Implementation Details
Parser Options
kGHMarkdownAutoLink: Enable automatic URL linking -
kGHMarkdownFootnotes: Enable footnote processing -
kGHMarkdownTOC: Enable table of contents generation -
kGHMarkdownSafeLinks: Restrict links to safe protocols -
kGHMarkdownNoHTMLTags: Disable HTML tag processing
Output Features
- HTML5 semantic markup
- Proper heading hierarchy
- Accessible table structures
- Clean, valid HTML output
Best Practices
- Use Tables Sparingly: Tables are powerful but can be complex to maintain
- Leverage Task Lists: Great for project management and documentation
- Utilize Autolinks: Let the processor handle URL conversion automatically
- Structure with Headings: Use proper heading hierarchy for better TOC generation
- Test on GitHub: Verify compatibility with GitHubâs rendering
Migration from Standard Markdown
Most standard Markdown works with Discount GFM without changes. To take advantage of GFM features:
- Add Tables: Convert data into GitHub-style table format
- Use Task Lists: Replace bullet points with checkboxes where appropriate
Enable Strikethrough: Use
~~text~~for crossed-out content - Leverage Autolinks: Remove manual link markup for simple URLs
- Structure Headings: Ensure proper heading hierarchy for TOC generation
Resources
- GitHub Flavored Markdown Spec
- Discount Library Documentation
- GitHub Markdown Guide
- Markdown Cheat Sheet
This documentation covers Discount GFM as implemented in Marked. For the most current information, always refer to the official GitHub Flavored Markdown specification.
