ProcessorĀ Selection
ProcessorĀ selection
MultiMarkdown (by Fletcher Penney) is an extension of Markdown (by John Gruber). All standard Markdown formatting is observed, and MultiMarkdown provides additional syntaxes for elements such as tables and footnotes.
Syntax
Thereās a Markdown Syntax guide under the help menu, or you can refer to John Gruberās original documentation.
MultiMarkdown extensions are documented by Fletcher Penney in this document.
AlternativeĀ rendering
You can choose between MultiMarkdown, Kramdown, CommonaMark, and Discount in the . Each offers additional features with a slightly different syntax (see for more details). In most cases, MultiMarkdown is preferred, but if you have files already using processor-specific syntax or you run into trouble rendering a Markdown file with MultiMarkdown, select Commonmark as your default processor.
