Streaming Preview
By opening File New Streaming Preview, Marked receives live updates over a named pasteboard instead of watching a file on disk. The source app must integrate with Marked.
Curio, Drafts, and The Archive document their own toggles and menu commands. nvUltra, nvALT, Bear, and others use the same channel: open streaming preview in Marked, enable integration in your editor, and start typing; updates arrive in near real time.
Developers
To integrate the Streaming Preview with your app, you just need to put the markdown text to preview on a named clipboard. Use the following code (Objective-C) to update, preferably on a didEndEditing method or at throttled intervals:
NSString *rawString = @"the text to process";
// pasteboard *must* be named 'mkStreamingPreview'
NSPasteboard* pb = [NSPasteboard pasteboardWithName:@"mkStreamingPreview"];
[pb clearContents];
[pb setString:rawString forType:(NSString*)kUTTypeUTF8PlainText];
Declaring a Base URL for relative assets
You can also provide a base url for the streaming preview, allowing relative URLs in images and other assets to function as they would in the source app. If the base URL includes a filename, its name and extension will be made available to custom processors, but it’s not required to do so. To include the base URL, simply put an NSURL object into the clipboard:
NSString *rawString = @"The text to be processed\\n\\n![](images/screenshots/mainwindow-feature-stats.jpg)";
NSURL *baseURL = [NSURL fileURLWithPath:@"/Users/username/Documents/HelpDocs/Main Window.md"];
[pb clearContents];
[pb writeObjects:@[rawString, baseURL]];
Or in Swift:
let rawString = "The text to be processed\n\n![](images/screenshots/mainwindow-feature-stats.jpg)"
let baseURL = URL(fileURLWithPath: "/Users/username/Documents/HelpDocs/Main Window.md")
let pb = NSPasteboard(name: "mkStreamingPreview")
pb.clearContents()
pb.writeObjects([rawString, baseURL])
If the Mac App Store version of Marked is being used and the baseURL isn’t accessible via sandboxing, permission will be requested the first time the URL is loaded in the preview.
Declaring the Source Application
Apps can also declare themselves as the source of the preview content by including a source metadata line. This will usually be accomplished within an HTML comment to allow compatibility with both GFM and MultiMarkdown processors. Simply state the app’s name or bundle id:
source: Bear.app
Opening the Streaming Preview Programatically
Your app can open the Streaming Preview programmatically using the x-marked-3://stream/ url handler method. This method also accepts an x-success parameter in which you can pass a bundle ID of an app to activate upon completion.
Next up: HTML Specific Settings ▶
