Style Stealer
Extract and steal styles from any website.
What is the Style Stealer?
The Style Stealer is a tool that allows you to extract CSS styles from any website and apply them to your Markdown documents as Custom Styles. Itâs perfect for:
- Bloggers who want to match the styling of their favorite websites
- Writers who need to create documents that match a specific brand or publication
- Developers who want to quickly prototype with existing design systems
- Anyone who wants to capture the look and feel of any well-designed website
The Style Stealer depends on a site to be relatively well laid out with clear markup divisions. It wonât work on every site, but it should do a good job on most.
For the best results, enter a page that contains as much text content as possible. For example, to extract styles from a blog, open directly to an article or post, not to the main index page.
How to Use the Style Stealer
Step 1: Open the Style Stealer
Access the Style Stealer through the Help â Style Stealer.
Step 2: Enter a URL
In the URL field, enter the address of the website you want to extract styles from. The Style Stealer works with any publicly accessible website. If the site is behind a paywall you may have to log in to be able to extract the content.
Step 3: Load and Navigate
Click Extract or press â to load the website. Once loaded, you can:
- Navigate the site using Command+Click on links
- Hover over content areas to see them highlighted
- Click on the main content area you want to extract styles from
The main content area you select should only contain headlines, paragraphs, lists, etc. Do not select a content area that contains menus, sidebars, or other extraneous content. Often a headline will be in a separate container from the regular paragraph content. In these cases, first try selecting the smallest container that still contains both. If the results are poor, click Extract again and re-select just the container that holds the paragraphs.
Step 4: Extract Styles
When you click the content area, the styles that apply to that area will be extracted. The preview will reload with a generic page that showcases all common HTML elements and how the extracted styles will apply to them.
You can then save this Custom Style to your Custom CSS folder for use in any document. Click the Save button or press â+S to save. The style will be named based on the domain of the URL you entered.
What Gets Extracted
The Style Stealer captures a comprehensive set of styles including:
Typography
- Font families and sizes for all heading levels (H1-H6)
- Paragraph styling including line height and spacing
- Text colors and background colors
- Font weights and styles (bold, italic, etc.)
Layout and Spacing
- Margins and padding for all elements
- Border styles and colors
- Background colors including body backgrounds for dark themes
Interactive Elements
- Link styles including hover and visited states
- Button and form element styling
- List styling (bullets, numbers, indentation)
Special Features
- First paragraph styling
- Blockquote formatting
- Code and pre-formatted text styling
- Table styling
- Custom font faces and web fonts
Advanced Features
Media Blocking
The Style Stealer automatically blocks media content (videos, images, audio) to prevent crashes and focus on text styling. This ensures a smooth extraction process even on media-heavy websites.
Pseudo-Selector Support
The tool captures CSS pseudo-selectors like:
:hoverstates for links and buttons -
:visitedlink states -
:first-childparagraph styling -
::first-letterfor drop caps
Smart Filtering
The Style Stealer intelligently filters out:
- Default browser styles
- Unnecessary vendor prefixes
- Conflicting or redundant rules
- Styles that would make text unreadable
Debug Mode
Enable debug mode in the Style Stealer to see detailed logging of the extraction process. This is helpful for troubleshooting or understanding what styles are being captured.
Tips for Best Results
Choose the Right Content Area
- Click on the main content area of the page, not headers, sidebars, or footers
- Look for the area that contains the article text, blog post, or main content
- Avoid areas with heavy JavaScript or dynamic content
Handle Dark Themes
The Style Stealer automatically captures body background colors, making it perfect for extracting dark theme styles. The preview will show how your content looks with the extracted dark styling.
Font Considerations
Web fonts are captured and included in the extracted styles
- Fonts that are loaded from a remote URL (e.g. Google Fonts) will maintain that URL. Fonts loaded from data URLs will be duplicated in the generated stylesheet.
- System fonts will fall back gracefully on different systems
- Font loading may take a moment in the preview
Testing Your Styles
After saving extracted styles:
- Apply them to a test document
- Check how they look with your actual content
Make adjustments by:
- Open the
- Select the new style in the Custom Styles table
- Click Reveal to show the file in Finder
- Open the file in any plain text editor (TextEdit will work in plain text mode) and make adjustments as needed
Troubleshooting
Website Wonât Load
- Check that the URL is correct and publicly accessible
- Some sites may block automated access
- Try a different page on the same site
Styles Look Different
- The extracted styles are based on the specific content you selected
- Some sites use complex CSS that may not translate perfectly
- Use Additional CSS or edit the stylesheet to make fine adjustments
Missing Styles
- Ensure you selected the main content area, not a sidebar or header
- Some styles may be applied via JavaScript and wonât be captured
- Check the debug console for detailed extraction information
Keyboard Shortcuts
- â - Load URL for extraction
- â+S - Save the extracted style to a Custom Style CSS file
- â-Click - Navigate links while previewing
Integration with Custom Styles
Extracted styles are saved to your Custom CSS folder and can be:
- Applied to any document through the Style menu
- Modified using any text editor
- Shared with others by copying the CSS file
- Combined with other custom styles
The Style Stealer makes it easy to build a library of beautiful styles inspired by the best-designed websites on the internet.
