Zoom Overview
Zoom Overview shrinks the preview text so you can see more of the document at once—useful for spotting structure, scanning for a section, or judging length without opening the Mini Map.
Using Zoom Overview
Press Z in the preview to zoom out. Press Z again to return to normal size. While zoomed, you can also press Escape or use the dismiss control on the Z tip to zoom back in.
Word Repetition visualization
The same Z shortcut applies when Word Repetition (⌃+⌘+W) is open: toggling the zoom helps you see where repeated words cluster in the document.
For a scaled thumbnail of the full page (with optional bookmark markers), see Document Navigation.
Next up: Autoscroll ▶
