Choosing a Processor
Marked can preview the same file with several built-in Markdown processors. Each one makes different tradeoffs between writing workflow (books, blogs, GitHub READMEs) and output control (IDs, classes, metadata). You choose the default in ; you can also override the processor per document.
This page summarizes how the four main processors differ. For full syntax details, see the reference pages under Help â Markdown Reference (e.g. MultiMarkdown v5 Specification, Kramdown Specification, CommonMark Specification, Discount GFM Specification).
MultiMarkdown (v5)
Best for: Long-form prose, academic or technical writing, and anything that relies on metadata, citations, and MultiMarkdown-specific features.
Marked ships with MultiMarkdown 5 (see the MultiMarkdown Userâs Guide for the upstream documentation).
Strengths
- Narrative and reference-heavy documents: Footnotes, bibliography/citations, and tables are first-class.
Metadata: Standard MultiMarkdown metadata blocks (
Key: Valueheaders) plus transclusion and other MMD conveniences described in the v5 guide. -
Metadata substitution: Keys from metadata can be inserted in the body with
[%key]-style replacement so titles, author strings, and similar values stay in sync with the header. - Tables, images, and cross-references: Aligned with the features documented for MultiMarkdown 5.
IDs and manual headings
- Heading IDs are normalized in a way that tends to produce lowercase, concatenated slugs (no spaces â words run together).
For manual header IDs, MultiMarkdown uses the form:
## Headline Text [my-id](the bracketed identifier after the heading text).
When to pick something else
If you need GitHub-flavored task lists and the exact behavior of GitHubâs current parser, prefer CommonMark (GFM). If you need fine-grained HTML classes/IDs on arbitrary elements, consider Kramdown.
Kramdown
Best for: Documents where you want precise control over HTML output â custom classes, IDs, and attributes, so your CSS can target specific blocks and spans.
The kramdown syntax reference is the authoritative guide.
Strengths
- Mostly compatible with MultiMarkdown-style habits for everyday Markdown, while adding its own extensions.
Inline and block attribute lists (IALs): Attach
{: #id .class key="value"}to paragraphs, headers, code blocks, links, images, and more â ideal for Jekyll-style sites and custom stylesheets. -
Header IDs: kramdown normalizes auto-generated header IDs to lowercase, hyphen-separated words (e.g.
my-section-title). For manual IDs, use the{#id}form after the headline text â e.g. Setext:My Section {#my-section}then the underline, or ATX:# My Section {#my-section}(see kramdownâs headers for exact placement and IAL rules). - Definition lists, footnotes, smart typography, math blocks: Rich feature set for publishing pipelines that need more than âplainâ Markdown.
If you rely on MultiMarkdown-only metadata substitution ([%key]) or MMD-specific citation workflows, MultiMarkdown may be a better fit. For README and repo docs that must match GitHub online, CommonMark (GFM) is usually closer.
CommonMark (GitHub Flavored Markdown /Â cmark-gfm)
Best for: README files, issue/PR descriptions, and project documentation that should match GitHubâs current Markdown behavior as closely as possible.
Marked uses a GFM-oriented engine (cmark-gfm). The formal spec is the GitHub Flavored Markdown Spec, built on CommonMark.
Strengths
- Closest match to GitHub: Tables, strikethrough, task list items, fenced code blocks with language tags, and autolinks behave like modern GitHub rendering.
- Unambiguous parsing: CommonMark defines block/inline precedence and list rules precisely â stricter in some edge cases than âclassicâ Markdown.pl behavior, but more predictable once you learn the rules.
- Practical for wrapped text: Paragraph and list rules are designed to behave well with hard-wrapped prose (see the specâs sections on lazy continuations and lists).
Header IDs
Auto-generated heading anchors are typically lowercase and hyphen-separated, consistent with common GitHub-style slugging.
GFM does not replicate MultiMarkdown metadata, kramdown IALs, or MMD citation workflows. For books, theses, or heavy metadata, use MultiMarkdown or Kramdown as appropriate.
Discount
Best for: A fast, C-based processor that tracks classic Markdown and an older GitHub-flavored feature set â useful when you want behavior closer to original Markdown plus tables, footnotes, and related extensions without the full CommonMark rule book.
Project home: Discount.
Strengths
- PHP Markdown Extra-style tables and many extensions (footnotes, fenced code when enabled, etc. â see Markedâs Discount GFM Specification for what Marked enables).
- Optional âGitHubâ extras in upstream Discount (e.g. checkbox lists when built with the right flags); Marked documents the combination it ships in the Discount spec page.
- SmartyPants-style typography and other conveniences described on the Discount site (though all included processors actually provide typography features).
- Philosophically close to John Gruberâs Markdown plus practical extensions, rather than the full CommonMark test suite.
For pixel-perfect parity with todayâs github.com, prefer CommonMark (GFM). For MultiMarkdown metadata and citations, use MultiMarkdown.
Quick comparison
| Concern | MultiMarkdown | Kramdown | CommonMark (GFM) | Discount |
| Primary use | Prose, papers, books | Styled HTML, Jekyll-like sites | READMEs, GitHub-like docs | Classic MD + extensions |
| Citations / MMD metadata | Strong | Via different syntax | No | No |
| Manual heading ID style |
## Title [id]
## Title {: #id } (IAL)
Spec / GitHub slug rules | None |
| Auto heading IDs | Lowercase concatenated | Lowercase hyphenated | Lowercase hyphenated | Lowercase-hyphenated |
| Extra attributes (classes/ids) | Limited MMD mechanisms | IALs â very strong | Limited | Limited |
See also
- Settings: Processor â default processor and related options
- Markdown Dingus â try processors side by side in Marked
- Custom Processor â plug in your own toolchain when needed
